mnboone
Front panel and Block diagram separate items in task bar
Status: Declined
Particularly when I have many VI's (and often also their block diagram) open, it gets very tricky to find the correct one in the list (as Windows lists them as e.g. "15 LabVIEW....") . It would be useful to split this up, eg. in an item "9 LabVIEW front panels" and "6 LabVIEW Block diagrams"
3 Comments
P@Anand
Trusted Enthusiast
Whatever you are suggesting belongs to the operating system's task and for the OS its LabVIEW (Even if you have a control, Project open it will be clubbed to one).
A Tip: Press Ctrl+Shift+W you will get a pop-up window showing the BD and FP seperately listed, you can use that to navigate to different places.
GuenterMueller
Active Participant
Good catch:  Ctrl+Shift+W (Window >> All Windows ...) is the right tool for this: The window is resizable and you can sort by column.
Darren
Proven Zealot
Status changed to: Declined
