6 | |
6 | |
3 | |
2 | |
2 |
Once in a while I complain about font issues in general (here, here, or here), but one of the really weird things are the font sizes as used in LabVIEW.
The font dialog lists them as units of pt, but for some reason they are quite different in size from the same sizes in any other applications (browser, word, etc.). LabVIEW also shows other problems, for example tahoma 14, 15 all look exactly the same... why??
Here is a side-by-side comparison of a wordpad document and a LabVIEW panel. Each line is configured for the indicated font size.
As you can easily see, LabVIEW is the exception. Any other applications I tried agrees with the left panel.
Idea -->LabVIEW should also standardize here!
Re-opening because LabVIEW NXG has been discontinued.
