| User | Kudos |
| 6 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
Format Into String can become very complicated when you have multiple inputs. I think implementing it in a way similar to the Formula Node could make it much better.
Ideally,
As a side note, the Formula Node itself could also benefit from the same color and hover highlighting.
