2 | |
2 | |
2 | |
2 | |
1 |
Currently if you create a new VI for override, whether or not the terminals are displayed as icons is determined by the VI being overridden (e.g. overriding Actor Core.vi will always give you terminals as icons). Instead, I propose that it be determined by the user's preference in the Tools--> Options menu. If we've said we don't want terminal icons, shouldn't all newly created VIs respect that?
