10 | |
3 | |
2 | |
2 | |
2 |
I find myself to replace controls to the preferred style and reorganize the labels (trough the quick drop shortcuts) for almost every accessor VI. For this purpose I ended up modifying the templates of these VIs, but I would prefer to have this in the script that creates these VIs, so they automatically match the setting made in LabVIEW options. This should include preferred control style, label placement of the controls on block diagram and also the front panel cleanup.
