It would be better if we could probe the auto indexed tunnel while the for loop is still executing.
If the For Loop is running for a huge number of iterations and if the Auto-indexed tunnel is having a condition. Then to check the values in the conditional auto-indexed array should be made possible even when the for loop is still running for debugging purpose.
If something like the below can be done it will be helpful in debugging.
