| User | Kudos |
| 6 | |
| 3 | |
| 2 | |
| 2 | |
| 1 |
The current implementation for front panel grid "contrast with background" actually changes the grid color from white (0%) to black (100%).
This can be annoying when your background color is not the standard gray.
It would be nicer to be able to select a color and use the slider for its opacity (alpha channel).
