Flatpak is a distribution-agnostic package manager, as long as Flatpak is installed on the system, the same Flatpak package can be installed on any distro. A Flatpak package contains not only the application, but the libraries needed to run it.
So, if NI creates flatpak package with LV and all of its dependencies, then we would have a LV that it's able to run in any distro! Without to having the hassle to manually support every major distro or (like at the moment) only supporting a few of them.
