In Visual Studio you have XML Schema tools etc. It is a breeze to e.g. populate a drop down menu based on XML from a web service, and my first thought when I see it in action is - why do we not have this at our fingertips in LabVIEW already? LabVIEW could have made it simple to create schemas, generate flexible XML etc. You could have wizards that helped you, and cluster to xml conversion like in EasyXML from JKI - and it should all feel fully integrated (toolkits are OK, but this really needs to have native support).
I am currently developing a web service in LabVIEW and the first thing I had to do was to abandon the few in-built XML functions and write my own serialization code (using terminal mode for the web service gave you XML without proper headers, and the in-built flatten to XML outputs XML is impractical in use). Once I have serialized a text table e.g. and published it - using that table feels incredibly easy in Visual Studio (add data source-> input web address etc.) , it would be much more difficult to do the same in LV.
I think NI should make a big leap in the use of web technology. The RESTful web service functionality was a great addition, but the doumentation is non-existing, and we should have come much further by now. I know there are some cool experiments going on with web based GUI editors, but LabVIEW 2010 was just released with very little news on this front so forgive me if I rant a bit...![]()
