13 | |
11 | |
3 | |
3 | |
3 |
The "Call Chain" primitive:
Sometimes I want it to behave exactly as it does today. But sometimes, like when I'm generating error logs and trying to only write down one copy of an error, I'd like it to give me the edit-time name of VIs instead of the run-time name of VIs. That means that reentrant clones would not include the trailing number.
I would like there to be an input (bool or enum) to specify the naming of clones in the call chain.
