This is a bit of a pet peeve of mine while programming, a tunnel placed at the midway of a structures edge will be covered by the resize handle when you want to move/select the tunnel. It would be nice if the tunnel had precidence over the resize handle on the structure, and as such would be cover the resize handle so that you could more easily access the tunnel instead of the other way around like it is now. If you need to resize the structure, there are handles at the edge of the structure, and a Ctrl press while resizing will lock the regrowth to one direction, so the center handle access really isn't as needed.
As it currently is
Would be nicer like this
Available in LabVIEW NXG 1.0. Hovering over a structure tunnel gives precedence to selecting and operating on the tunnel over the resize grab handle.
