8 | |
6 | |
4 | |
3 | |
2 |
Recently we do not have real control on the shortcut menu. We can modify/disable the Graph's Run-Time shortcut menu, and we can access Events of selection for example. This does not work for the Plot Legend: if someone wants to use the legend, but for example exclude some of its options from the menu list, recently is not possible. We have neither Events associated with the Plot Legend Run-Time Menu Shortcuts.
Could this be fixed/enhanced? Either to give an option to have the same custom modification as for the Graph's menu, and/or get Events (filtered too) for this menu.
What do you think?
Idea came from this post: http://forums.ni.com/t5/LabVIEW/Export-Data-Right-Click-Graph-Display-Format/m-p/3337820/highlight/t...
