| User | Kudos |
| 5 | |
| 3 | |
| 2 | |
| 2 | |
| 2 |
For anyone that has used CAD software, you know how much of a timesaver this feature is. It is very similar to quick drop but relies more on graphical selection than keyboard input (although, these shortcuts often allow text entry as well and have a configurable menu).
For example, pressing the "S" key in SolidWorks pops up a contextual, configurable menu at the current cursor position that allows you to rapidly click on common operations as well as customized shortcuts.
I have my own janky extension to quickdrop that makes a graphical menu present after pressing multiple buttons (ctrl+space, ctrl+q, then one of WASD or a mouse click on the popup .vi front panel), but it would be nice if I didn't have to go through multiple shortcut selections to hit my toolbar-of-target. Said another way, a more extensible quickdrop-like shortcut bar would be nice. Something like the right click and shortcut keypresses for Autodesk Fusion and Solidworks are the inspiration.
