6 | |
6 | |
3 | |
2 | |
2 |
When we have to debugging a code where we use "Class", "Actor",... and we defined VI as "Shared clone reentrant execution" or "Preallocated clone reentrant execution" and we put the breakpoint, and the code is used by many instances, many pop-up windows will start to appear, which causes the execution flow to be stopped at several points.
LabVIEW has two useful tools to debugging errors such as "Desktop Execution Trace Toolkit" and "Monitored Actor Toolkit" for Actor, but in this case, our proposal consists of providing some functionality to "Breakpoint Manager", for example: the last time it was executed, if vi is paused,...
Only thing we intend is to avoid having to go through the windows until we find the windows that are blinking through a breakpoint and we can identify them in a simpler way.
