| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
The most common icon that I use in LabVIEW has a "title" section at the top. It is so common, that when this is used, LabVIEW moves the Text Entries below it. BUT, they don't allow for automatic entry INTO the title field. Instead they allow 4 lines of text that all gets compressed when you use 4 lines of text.
Instead of the 4th line of text, how about an entry for the Title, it will appear in the small window at the top of the icon.
Please refer to the discussion on the open source Icon Editor for why this Idea was declined: https://github.com/ni/labview-icon-editor/issues/172
