6 | |
6 | |
3 | |
2 | |
2 |
The import Web Service tool is very interesting and practical. However, many companies are using web services with authentication in xml script. This import tool doesn't work with the WSE3 protocol, from Microsoft, one of the authentication tools for soap services. I expect to see this implementation in the next version of LabVIEW.
