I've often produced VIs with non-array controls and indicators only to find that by changing them to arrays I can increase the power and functionality of my VI. When this happens you have to create the array element, drop in your control and then if it is connected to a VI input or output pin, rewire the pin.
What would be nice is to simply have the Add Dimension capability available for a non-array control to instantly convert it to an array and conversely the Remove Dimension to convert a 1D array control back to a non-arrayed control.
Available in LabVIEW 2015 and later. You can right-click a scalar control and choose 'Change to Array', and you can right-click an array control and choose 'Change to Element'.
