JÞB
Improve Error Ring
Status: Declined
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
Don't get me wrong. I really like it that the error ring is back! I just think it needs a few features.  Specifically, RCM options to replace with error constant and replace error constant with error ring.  (This should also work with any green cluster)
Please Stephen? Can I have it in time for Christmas?
4 Comments
AristosQueue (NI)
NI Employee (retired)
I don't know the acronym "RCM". And you probably can't have it for Christmas because I'm working on other stuff. But I like the idea generally. 🙂
crossrulz
Knight of NI
RCM = Right Click Menu
JÞB
Knight of NI
thank you crossrulz!  yes, right-click an error constant or termial,  and "Replace with Error Ring" should be available (AND populate the ring with the current error data) Right-click an error ring and "Create> Control/ Indicator/ Constant" should be available.  We won't speak of my desire to fix my Crtl+! custom menu short-cut that still does not pick up the error ring or error cluster contents for the explain error dialog.
Darren
Proven Zealot
Status changed to: Declined
