6 | |
6 | |
3 | |
2 | |
2 |
I frequently use the "New VI for Override" feature in my projects. Problem is, I always have to add a case structure with an error case and I rarely use the call parent method. I'd like to see something like the template for "New VI for Dynamic Dispatch" but with the call to the parent in the case structure.
Casey
Phoenix, LLC
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
