6 | |
2 | |
2 | |
1 | |
1 |
As far as I can tell the SMTP Email VIs on the SMTP Email pallet do not support any sort of authentification. Unless I am missing something this makes them close to useless. It definately makes them usless to me.
I think there should be a login (and logout) VI where the login session is passed into the other VIs via a reference object.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
