Classes? OOP? ... Huh?
Even if you don't (yet) work with LV classes, you may have noticed that they are starting to become increasingly widespread in the LV world. In fact, the excellent new Actor Framework that ships with LV2012 relies heavily on classes. LV classes are great but they can impact on your performance as a developer as your application becomes larger. I'd encourage everyone to click the magic KUDOS button for this idea, since classes will likely affect us all sooner or later!
The problem:
Most class-based architectures contain some degree of linking. One form of linking is inheritance where parent-child relationships are implicitly defined, and another form of linking arises from nesting libraries where classes (e.g.) are placed inside other libraries.
Unfortunately as the linking increases in a project, the IDE starts to become very sluggish! Those who have worked on mid-sized class-based applications know the symptoms:
For many projects these symptoms are a minor annoyance, but as your project grows they can become a serious impediment to productivity. Why should it take over 30 seconds to modify a class's inheritance?!
Obviously careful design can reduce linking to some extent, but that just postpones the pain. The reality is that all class-based projects start to suffer from these symptoms once they reach a "resonable" size.
The idea:
Improve the responsiveness of the LV editor when working with classes.
Credits:
Others have written about this topic well before me. Here are a few relevant discussions:
Feel free to link more! ![]()
