kosist90
Improve default shipping quick-drop for function insert Ctrl + I
Status: Declined
The issue was caused by a third-party add-on. In the current LabVIEW release, the 'Insert' Quick Drop plugin properly inserts a node on a single selected wire segment.
Currently, while inserting node by default insert quick drop Ctrl + I, it inserts node without considering wire branching. Check the picture - first is target place, and second - where it is actually inserted. Using insert menu from right-click menu works fine, b/c it inserts function exactly to proper place.
It would be nice to update this quick drop, to have the same behaviour, as non-quick drop functionality.
Sincerely, kosist90
12 Comments
wiebe@CARYA
Knight of NI
>Is it possible to delete this idea then?
Select "Options>Report to a Moderator", and ask the moderators to delete the thread.
I wouldn't mind keeping it, it will be closed soon. Perhaps moving (to a Saphir forum maybe) it is better then deleting it? Seems like you found an issue that can benefit others (Saphir developers for instance).
Darren
Proven Zealot
Status changed to: Declined
