| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
When I add block diagram comments inside a structure, they are often long enough to require several lines. Since auto-grow is on, I need to stop typing before the comment reaches the edge of the structure, resize the comment to be multi-line, select inside the comment again, and re-start typing. From then on, the comment word wraps at my sized width. Could you make a special character like ctrl-, alt-, or Shift-comment move me to the next line and make the comment that wide, so it word wraps at that width from then on? While you're at it, could a word-wrapping comment autogrow in height to fit the comment, like a one-line comment auto-grows in width? Subdiagram comments could use that feature, too.
