| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
In LabVIEW, we can create a polymorphic VI, but polymorphic VIs are made by creating multiple disparate VIs and logically tying them together. What I'm proposing is a single VI which can be used to perform many different functions, as is normal in many text languages.
Imagine a class with 10 different functions, and the ability to read/write from each. We'd have 20 similar VIs. I propose a single VI with a tabbed front panel. When you select a different tab, you'd see a different block diagram. Each could have a different connector pane. When saved, it would create a single file. On a palette, it would be a single function. We could use a polymorphic selector to choose which function to operate on.
This would simplify distribution of classes and drivers.
