3 | |
3 | |
2 | |
2 | |
1 |
I have been using some polymorphic VIs lately and I believe there can some improvements to the interface.
1. If I add a new VI to a polymorphic VI, the list should scroll automatically to the end and highlight the item that has been added recently.
- Highlighting does not work all the time as of now. If you have selected the first VI in your polymorphic VI and then Add, it will highlight the recently added item. If you have selected any other row and press Add, it highlights one row before the row it was originally highlighting. (I guess it's doing some circular kind of action) I am not sure if this is more kinda bug!
2. Able to move multiple items at once - I can move only one item up/down right now. Ability to just drag, drop multiple items and change the order would be great!
3. If I click on any instance VI, it opens up that VI. If I click on the same instance VI but in the menu name/selector name columns, it should open up the "Edit Instance Name" dialog box. It's really hectic when I have my Polymorphic VI fully maximized, selecting an instance VI, coming to the bottom, pressing Edit Name button and editing the names.
Another option is to right click on the instance VI and select Edit Name.
Saranya
