13 | |
11 | |
3 | |
3 | |
3 |
In Place Structure (Unbundle - Bundle)
Please ... enable also the others!
it would be easier to swap between two inputs (or outputs)
In Place Structure (Unbundle - Bundle) should work like the behavior of the original Bundle-Unbundle,
like this,
