6 | |
2 | |
2 | |
2 | |
2 |
In the properties of a subVI reference, you can get the name and reference of the VI.
When The VI is re-entrant, with this property then you get the name and reference to the "Model" VI but NOT to the Clone associated to the subVI.
In scripting activities, it would be usefull to be able to get the name and/or reference of the Clone VI of an instance subVI...
For example, in development mode, I have a instance subVI of a re-entrant on which I need to put a breakpoint by scripting at runtime for debug purposes. This is something I actually can't do.
I think that's this is something easy and that might already exist (in private properties of subVIs ???) because when you double click on a subVI instance of a re-entrant VI, then the front panel of the clone (i.e. copy) of the original VI is opened. So there's somewhere a link between the subVI (reference) and the Clone VI.
(it's already possible in VI property to get the Clone name when this VI is re-entrant).
(Hope I'm clear...)
