8 | |
6 | |
4 | |
3 | |
2 |
We have quite a few LabVIEW users here, but not many of us have the application builder or the experience to use it. So I get many requests to build an executable and installer for others. Each time I have to take their DaqMX tasks (in the form of a *.nce file from their machine), import it into my MAX and then when creating the installer essentially re-create the same file. Can an option be added to the Hardware Configuration tab to allow you to select a NCE file instead of create one?
-Brian
