Brian.Schork
Include the capability to choose a *.nce file when creating an installer instead of having to re-create it.
Status: New
We have quite a few LabVIEW users here, but not many of us have the application builder or the experience to use it.  So I get many requests to build an executable and installer for others.  Each time I have to take their DaqMX tasks (in the form of a *.nce file from their machine), import it into my MAX and then when creating the installer essentially re-create the same file.  Can an option be added to the Hardware Configuration tab to allow you to select a NCE file instead of create one?
-Brian
2 Comments
CDreike1
I don't see this request as optional. It is a necessity for anyone using a non-emulatable device such as a USB-600X device.
Please add this feature!!
Chris
MichaelBalzer
Active Participant
7 years on and I'm running into this. I am rebuilding an installer for a newer DAQmx hardware configuration and have an updated NCE file, but no hardware access.
FWIW the lvproj file can be hand edited to choose a custom NCE file path (look for MSI_hwPath). Tedious and no doubt unsupported, but it seems to work.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
