8 | |
6 | |
5 | |
4 | |
3 |
Hi all,
Sometimes, I use the index array node for getting elements 0-8 from an array, for example. If I need to use the 6th elements from the output of the index array multiple of time during coding, I find myself counting every time to make sure that I am using the 7th element. It will be nice if there is a very small number on the index array node to indicate which output is which element of the array. I think it will be clearer.
Yik
