| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
While taking the zeroth index of an empty array of Enum, it is giving the default value of Enum as output.
If it is an empty array, it should give an empty enum type, instead of giving default value of enum as zeroth index of the empty array.
Declined for reasons listed here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Indexing-the-empty-array/idc-p/3202258#M32763
