| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
I find myself wiring errors out of the loop using auto-indexing and then immediately using a merge errors on the array of errors. With the addition of the Loop Terminals for concatenating arrays and conditional arrays, please add one on error wire terminals that can do the merge errors in one step.
For Example, current implementation:
What I would like to have but would do the same thing in one step:
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
