Hi all
This is my first hint in LV idea exchange: smileyvery-happy:
A freshly dropped local or global is by default in "write mode":
Switching it to "read mode" requires to go through the not-very-funny process: "right-click", "change to write", then you have :
My proposal is to create kinds of polymorphic feature, so that a newly dropped unconnected Local/Global would have both read/ write connector:
Of course, as soon as one side is connected, the opposite connector vanishes.
Disclaimer :
I know I'am exposing myself to locals-use-and-abuse bashing posting this idea ![]()
So I probably need to ad "Abusing of locals or globals is bad for you health, can kill, or worse create totally unexpected behaviour in you application" ![]()
cheers !
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Wiring-to-Determine-Property-Node-Read-Write/idi...
