From time to time it would be handy to have an "insert again" option on the context-sensitive menu; not necessarily a history for insert (as suggested at https://forums.ni.com/t5/LabVIEW-Idea-Exchange/History-for-insert/idi-p/1524082 where the poster does mention a single-item history) nor as extensive as QuickDrop - just a simple repeat of the last inserted item. Here is an example of being able to insert another conversion identical to the one just inserted, with a minimum of mousing and no keystrokes.
One (probably superior) alternative would be to change the behavior of <ctrl><right-click>; hovering over a wire and pressing <ctrl> shows the wiring tool, and a right click could repeat the last insertion (instead of bringing up the context-sensitive menu, which is a redundant behavior and a squandered control sequence).
