8 | |
5 | |
4 | |
3 | |
3 |
If one had to explain the architecture of a larger project to a new person that implements classes & interfaces without referring to a top level UML diagram, the eyes could quickly start to glaze. Adding simple functionality may prove to not be so simple.
Perhaps adding to the context help when hovering on the wire showing the hierarchy would be helpful as outlined below.
Note: Kudos to Piotr for making the code available. Thank you!
