| User | Kudos |
| 11 | |
| 10 | |
| 10 | |
| 5 | |
| 4 |
Currently to AutoScale an axis once, you need to set the ScaleFitX/Y property to 1. However this is really just like calling a method since the value of the ScaleFit property remains whatever it was previously. As a result, I find this mechanism unintuitive and would prefer to use the invoke node to call a suitable method named ScaleFitX/Y since it is an operation that just happens at a moment in time rather than changing a property.
Current Method: Property Node
Proposed Idea: Invoke Node
