| User | Kudos |
| 12 | |
| 12 | |
| 9 | |
| 9 | |
| 5 |
When selecting objects on the Front Panel and using the Shift + Up or Down arrow key, it moves them to the nearest grid line and successive shift+arrow keys keep things on the grid. This is fine when selecting a single object, However, when selecting multiple objects that are not perfectly aligned, it may result in a misalignment.
The idea being suggested is when multiple objects are selected they should retain the original alignment between objects. A more sophisticated version could allow the user to select in the options whether objects that are aligned within a given small number of pixels should automatically be perfectly aligned and moved together. The idea is to prevent having to re-align an object after using the Shift + Arrow to move them.
See image below:
