13 | |
11 | |
3 | |
3 | |
2 |
If you copy a group of controls/indicators from a front panel to another, the layout of their terminals on the block diagram is not maintained (instead it is typically messy...)
Vice versa: If you copy terminals from a block diagram to block diagram the block diagram remains the same, but the control layout is messed up.
Why not just keep both as they were when copying?
Bonus-idea: If you try to fix this by using the diagram clean-up function controls with the same name, but an iterative suffix (which the IDE is able to automatically generate itself as well, so it has a relation to it alread) the clean-up ignores the order of the names when ordering the controls...(so it might stack them nicely, but then control ...<n+1> is not put after/below ...<n> e.g. Perhaps it could be a bit more intelligent and include that in the ordering algorithm too?
