ouadji
LVPROJ : Rename a folder
Status: New
                              lvproj : be able to rename a folder
22 Comments
crossrulz
Knight of NI
I just did an experiement hoping that the Move on Disk would do the job.  Nope, it just moves the selected folder to another folder location.  And I know of times where this renaming of a folder would be quite helpful.
GCentral
ouadji
Trusted Enthusiast
@crossrulz :
No, it's a shame. I thought that too.  Smiley Frustrated
PaulG.
Active Participant
The LV project environment really needs to be a lot more transparent with the native OS. I would give the LV Project environment an "A" if it were a little more seamless. I think that would alleviate many of the conflicts I get in the project environment.
PaulG.
Retired
ToeCutter
Active Participant
Definitely needed.
Knight of NI
Hm, I opened a project. Then I click on a project's folder name like I used to in WindowsExplorer. Wait a second (or two) and you can rename the folder as you could do to a folder in WinExplorer…
Did I miss an important fact here?
crossrulz
Knight of NI
@GerdW
Were you in the Files view?  That isn't working for me.  Now in the Items view, you can rename virtual folders that way.
GCentral
JÞB
Knight of NI
OK, I'll say it again. STOP Auto-populating your project's virtual folders!
Why would you want to rename one of the OS's Folders from a LabVIEW Development Enviornment?  Can you do it from Acrobat? Office? a web browser? Notepad?  nope, nope, nope, nope!
BUT, you do have that "Explore..." Right there on top to launch OS-Explorer (Windows Explorer in this case) and engage the resource that owns "folder renaming"
At the risk of sounding harsh, I'll say it anyway.  This idea is absurd.
fabric
Active Participant
Jeff: The idea may be absurd to you, but it would have quite a lot of value for me. I suspect we probably like different foods too! Smiley Tongue
The key point here is that LabVIEW relies quite heavily on knowing where files are, and if you close your project, rename some folders, and then reopen your project you are often met with a long list of confused callers.
Why then would you frown upon a tool that allows you to *safely* achieve the same result from within the project itself, thereby eliminating all the "caller confusion"? My guess is that *you* don't rename things... but many of us do!
Anyway, a simple solution would seem to be to allow the Move on Disk function to perform an optional rename. Kudos for that!
ouadji
Trusted Enthusiast
fabric :
you are often met with a long list of confused callers.    +1
My guess is that *you* don't rename things... but many of us do!     +1
JÞB
Knight of NI
Certianly I rename things.
Certianly, I use the project explorer to move the files in my project!  And, within windows (the OS)
How often did you take you father's car?  Did you park it where he expected too find it?
The owner of the thing should be aware of where it is located!  If that is "Daddy's car" or an lvlib member.
Use projet exploer to move items.  use windows explorer to create conflicts.  then resolve the conflicts. MO. I'll try the formerSmiley Surprised
