5 | |
5 | |
2 | |
2 | |
2 |
I've been trying to follow google's material design guidelines.
There are many things I struggle with when building a UI in LabVIEW... I think following a set of guidelines designed by google is a good starting point.
LabVIEW UI capabilities should evolve to help us implement material design UIs
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
