| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
The BeagleBoard xM is a 32 bit ARM based microcontroller board that is very popular. It would be great if we could programme it in LabVIEW. This product could leverage off the already available LabVIEW Embedded for ARM and the LabVIEW Microcontroller SDK (or other methods of getting LabVIEW to run on it).
The BeagleBoard xM is $149 and is open hardware. The BeagleBoard xM uses an ARM Cortex A8 running at 1,000 MHz resulting in 2,000 MIPS of performance. By way of comparison, the current LabVIEW Embedded for ARM Tier 1 (out-of-the-box experience) boards have only 60 MIPS of processing power. So, about 33 times the processing power!
Wouldn’t it be great to programme the BeagleBoard xM in LabVIEW?
Available in LabVIEW 2020 Community Edition and later. The Community Edition includes the LINX Toolkit, which provides support for programming the BeagleBone Black.
