10 | |
3 | |
2 | |
2 | |
2 |
The LM3S9D96 Development Kit is a 32 bit ARM based microcontroller board that is popular and has several plug in boards. It would be great if we could programme it in LabVIEW. This product could leverage off the already available LabVIEW Embedded for ARM and the LabVIEW Microcontroller SDK.
The LM3S9D96 Development Kit costs $425 and is open hardware. The LM3S9D96 is an ARM Cortex M3 running at 80 MHz resulting in 96 MIPS of performance. By way of comparison, the current LabVIEW Embedded for ARM Tier 1 (out-of-the-box experience) boards have only 60 MIPS of processing power.
The LM3S9B96 Development Kit brochure (http://www.ti.com/lit/ml/spmt158e/spmt158e.pdf) already states, “The LM3S9B96 development board is also a useful development vehicle for systems programmed using tools such as Microsoft’s .NET Micro Framework and Embedded LabView from National Instruments”. So, the brochure already states that the board can be programmed using LabVIEW. Unfortunately, this is not so - not without a few months work. No one has done the Tier 2 to Tier 1 port and it would make the most sense for National Instruments to do this once for the benefit of all. Relatively little work to enable this interesting development board. And the marketing is already done!
Wouldn’t it be great to programme the LM3S9D96 Development Kit in LabVIEW?
