11 | |
8 | |
3 | |
3 | |
2 |
It would help to have an option to ignore Bad VIs errors when calling a mass compile via LabVIEWCLI. This makes the CLI MassCompile unusable for deploying code with NI Package Manager that has API Tree VI. It would help to have an option to ignore those errors so that NI Package custom execute could run successfully. I would think it could be defined as optional argument. My suggestion for the argument is -IgnoreBadVIs true|false with a default of false.
