6 | |
5 | |
3 | |
2 | |
2 |
Very often you get into the situation where you always have to do the same hundred clicks in the same order.
My suggestion: make shortcuts for every LabView menu item, also the context menues user defineable (right click on controls etc., e.g. "set control to typedef" or "set cluster autosize to arrange vertically" etc. It is the same with the cluster constants in the block diagram, not only with controls/indicators on the front panel. Additionally it might be really an option to record little macros and make those macros available via short cuts, like you are used to have in MS tools.
Comment: I know you can do a lot of stuff with VI server, but nevertheless: recording makros as a LabView function would just be more comfortable ...
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
