3 | |
3 | |
2 | |
2 | |
2 |
I've recently been handed the task to reevaluate our NI licensing needs. We're currently using a DevSuite setup, with some add on modules and sourcing wants me to evaluate a setup with Labview Professional and the associated add on modules.
Now I have a large code base to check and it would be good if there were a tool which would automatically tell me which add-on modules are used in a specific project. It could be a menu selection in the tools menu called "List Used Add-On Modules" that checks the project for vi's from add-on modules and lists these.
Br,
Albert Lederer
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
