Hi, first I'd like to say I am new to Labview, just passed the CLAD. I recently came across a post by someone who mentioned how difficult it can be to cut and paste code in Labview (or I guess even select everything necessary to make a SubVI). I thought a lasso select tool would be helpful in this case. There could potentially even be multiple versions, such as freehand, and one that can draw an arbitrary shape with straight lines (would be like drawing a wire around what you want to copy, and at every point where you want to change directions double click or something). I actually saw someone request something similar in an old post, but did not see this in Idea Exchange.
