There are times where I need to refactor an application's code and I use "Find" from the project explorer window to locate caller's of a specific VI. Once the list is populated, I would like to visit each of the "Callers" in the list and review the code. However, when I pick an item from the list, the Find result dialog box is dismissed. I need to re-do the Find and keep track of the VI's I have looked at manually. This feature would be more useful if the Find results remained visible and I could interract with it like I do with the "Error List" dialog, or the "Search Results" dialog box.
