When you are working with typedefs and classes in LabVIEW, context help can be very useful to sumarize everything that is contained in the class. This list can get very long if the class gets complicated, and has other references to other classes. If you want to know the full path to one of these typedefs, or you want to look at the class library, it would be nice it you could click on the filename and it would open that item in another window.
Otherwise you have to do some looking around to figure out what exact typedef or class the VI is referring to.
