6 | |
6 | |
3 | |
2 | |
2 |
In "Case Structure", when we use "Linked Input Tunnel" and select one end of the tunnel, is it possible to highlight the opposite end? as is the case with "Shift Register".
We have crossed the wires on purpose, because it isn`t always possible to make a straight line.
