8 | |
6 | |
4 | |
3 | |
2 |
Being a huge fan of linked input tunnels, I get peeved every time I'm working on an enum-based state machine because I usually want to pass the case selector through the handling case structure but I CANNOT create a linked input tunnel with a case selector. Instead I need to fork the wire and take the risk that my sloppy code will result in the imemdiate painful end of mankind. No, not really. But in that moment, it kind of feels like that.
That is all.
Shane.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Case-Terminal-to-be-selectecd-as-Linked-Input-Tu...
